- Doc_ReyExplorerReplaced Trimark Enterance Door Latch/Lock. A little modification required, otherwise turned out well.
- sundancer268ExplorerInstalled the second of three MaxAir Window Louvers.
- Dutch_12078Explorer IIIChecked the oil, transmission fluid, and windshield washer fluid levels, tire pressures via TPMS, topped off the fresh water tank, and gave it a bath in preparation for moving to a COE park in PA tomorrow.
- LancsladExplorerReplaced the left rear jack hose which had pulled out of it's fitting. It must have been under tension and finally gave way 'cause I couldn't get it to join up. The new one I had made at a local hyd shop was a foot longer and rubber instead of plastic. I expect the others will fail eventually but I checked and none were under tension.
Also filled the coach batteries and scrubbed the fiberglass roof with car wash/ wax. (Dollar Tree $1.00). Worked OK and the rain will rinse it off!!:D - Blaster_ManExplorerTook it to the Cat scales and weighed it...43,560...not loaded to travel, and with about 900# worth of fuel and water.
- robertbenitaExplorerStill waiting on the 16 ply Michelin tires for my coach. Michelin needs to hurry up and catch up to demand with their supply!
- mike_brezExplorer
sailor_lou wrote:
Although I didn't do the work (just paid for it) I had six new tires installed yesterday.
Lou
05 Travel Supreme Envoy
What brand did you go with? - sailor_louExplorerAlthough I didn't do the work (just paid for it) I had six new tires installed yesterday.
Lou
05 Travel Supreme Envoy - jyrostngExplorer30' Southwind 454 I installed a 2x3x1/4 wall piece of rectangular tubing in the pockets of the tow hitch extension to allow me to tow a racecar on a trailer safely. I tied it into the frame rails and bolted it at the back with the hitch .
- turbojimmyExplorerGot an inverter to run small stuff while dry camping (TV, DirecTV receiver, boombox). The top 'o the propane tank is not a permanent installation. I'm going to mount it in the power cord storage compartment so I can plug right into it. It's 2,000 watts so I can't/won't run the A/C with it, but it will do just about anything else.
As an aside, I couldn't get the dish lined up during my first real test of it out in the field (NASCAR event). Turns out it was lined up, the receiver just needed reauthorized. I need to remember to do that before embarking on my next journey.
Also, if you have a really sharp eye you'll see a new Autometer water temp gauge sitting on the console. A project for another day, but I have to get the cooling system under control. The 454 is running really hot.
38,763 PostsLatest Activity: Mar 21, 2016
