- Go_Dawgs1ExplorerFinally got the old Allegro 87 33' out of the garage so my friend can pick it up and put our Class C 26' in the garage. Nice and dry so I can begin to work on the exterior minor needs.
- snowdanceExplorerWe are having sunny dry weather for the next few days (25 degree nights and 45-50 degree days). Pulled the cover and cranked up the heat, checked the tires and took it for a 85 mile ride around the Shasta valley. Started first touch of the starter and ran nice. Hard part was parking it again. Plan to use the nice afternoons to do some work under and some cabinet changes inside. But winter will be back for us.. So will like as not cover it again in a week or so.
- taylorgsoExplorerInstalled electronic deer alert on new Sprinter MH
- noe-placeExplorerStarted engine and let run 30mins, checked and charged all batts.
- snowdanceExplorerHad a couple warm days and the holding tank heaters are finished and working. Ran the generator while checking the heaters. Was an easy job.. Hope to get up to Medford, Or. in the next couple weeks to Home Depot and get some insulation for them.
- snowdanceExplorerRounding up the things needed to install the holding tank heaters that I now have(My water tank is inside). And trying to figure where I can run the wire and a good switch location so we can start using the rig earlier and later. Still way to cold to lay on the ground to do the work. Come on spring.
- beardfamilyExplorerRaised the driver seat 1.5" using steel blocks - didn't get the seat to recline anymore, but improved the view out the window! Seat is still too straight up and down when pushed all the way back.
- dgcarverExplorer
BJean wrote:
Put a new lock set on entry door. Lucky we have 2 front doors when we found we were locked in unit.
That sounds like a joke I've heard! - Go_Dawgs1ExplorerFinsihed the polishing of the cabnets. Friday to the shop to have the front bearings packed and then sanitize the water tank for use. Taking a day trip in 9 days. The DW is finishing with the interior redecorating.
- BJeanExplorerPut a new lock set on entry door. Lucky we have 2 front doors when we found we were locked in unit.
38,769 PostsLatest Activity: Dec 31, 2014
