- TJDaveExplorer26' class C. 2004 Jeep Wrangler toad.
We measure FPT's, not MPG's.>>>>> Fun Per Tow! - John___AngelaExplorerWe know a few folks with the fit and all really like them after at least a year. If we ever need a bigger car the fit is something we would consider. Not pricey and well featured. In the meantime we'll keep driving our little CDI smart cars. It would be very hard to switch to something getting less than 60 mpg again. :).
- dtomlinsonExplorerWe have towed many different rigs over the years, but we now tow a Honda Fit behind the Aspect and it is great. You hardly know its back there, I keep rear view camera on to keep an eye on it. Its very roomy for such a small car, lots of rear storage for extras, plus it gets about 34 miles per gal. average.
- BobboExplorer IIThe first question is what is the weight limit your MH can tow. A limit of 3,500 pounds is common, as is 5,000 pounds. I try to stay at or below 80% of the limit in order not to stress the system. My MH has a 5,000 pound weight limit so I use a max of 4,000 pounds in my search. I ended up with a 2010 Subaru Forester (bought new in 2010). Keep in mind that a Subaru must be a standard transmission to tow. You can not tow an automatic Subaru except on a trailer. Not even on a tow dolly.
- Johnny_DearbornExplorerBlue Ox has a PDF with a list of all the towable cars on the market. It's worth the download.
Honestly though, for the length you've got, I doubt you need a toad. I thought I needed one until I took my first long trip with my 23 footer. So glad I didn't run out and buy one. Getting in and around spots would have been such a hassle. Most of the time, I wanted my RV with me.
Maybe if you're going to be parking it in one spot for long periods of time, I can see wanting a toad. But if you're touring and traveling, I suspect it will be more hassle than it's worth. Try traveling without it and see how it works out. - DakzukiExplorerYou must first ask yourself what you want the toad to do. Do you want to go off road, dirt roads, or strictly pavement?
For me was I wanted full on off road capability to go exploring. That means 4wd, some ground clearance, and Hi/Lo transfer case. I found that in a 2000 Chev tracker 2 door. It is also well under 3000 lbs. I keep the rear seat folded down so it's essentially a 2 seater with a cargo area. It does the job for us. Unlike a lot of folks we do in fact use the off road capability of the Tracker. It's not a Jeep Rubicon but it gets the job done.
If you are just tooling around on pavement, then your needs are much different than mine. - Hank85713Explorernot to hijack but what are you using for the required brakes on these? Just read on another site that most states require brakes on the dolly or the towed vehicle?
- captron1966ExplorerA Jeep Wrangler. Very light and you do not even know it is behind you.
- John___AngelaExplorerWe occasionally tow this
behind this
It is a 2005 diesel smart car. On the trailer a little over 2000 pounds - rockhillmanorExplorer II
MiniTT wrote:
Forgive me if this has been answered. We just bought a new 24 foot Solera diesel . What do you suggest we purchase as a toad? We have had several trailers but this is our first motorhome. Thanks for helping me out ..
Find the lightest weight car you can find.
When I went shopping for my first toad I looked at EVERYTHING. I was pretty shocked how much even the smallest compact car weighed. I couldn't find anything under 4,000 lbs.
I lucked out and found a used Chevy Tracker 4x4, 4dr. weighs in around 2,800 lbs. Just by shear luck I found the most desirable little toad. I get offers on her at just about every CG I stop at.
2 Important Tips I'll share from 'my' first experience:
1. Do NOT believe ANY salesman when they say YES this car can be towed "4 down". Buy your toad based on what the 'owners manual' says about towing 4 down and nothing else.
2. Do not believe ANY salesman that tells you yes this car is lightweight enough for you to tow. Look at the weight on the door yourself.
All the car salesmen I ran into lied about everything regarding 4 down towing. Thank God and for this forum that I learned that every owners manual has all the info you need about whether a particular car can be towed 4 down or not.
Long story short.....keep the toad lightweight you won't regret it and your RV will love you for it!
38,708 PostsLatest Activity: Mar 05, 2025
