rgatijnet1
Jul 10, 2014Explorer III
These are direct replacements for most clearance lights. They are sealed, with no outside lens/cover to remove. They can be set in caulking and will solve your leak problem permanently. Since they are sealed, if you drive your coach underwater, they will still operate. Order the two wire type light because with a fiberglass front and rear cap, you can not use the mounting surface as a ground. These are brighter than the single bulb incandescent clearance light that they replace and mine are going on 4 years without a single failure. Polarity must be observed when wiring these in to your rigs wiring. Clearance lights
38,776 PostsLatest Activity: May 15, 2026
