Dutch_12078
Jul 12, 2014Explorer III
Bigdog wrote:
I wish that they would flash when you activate your turn signals so that folks alongside you know you want to change lanes.
I have found on occasion that activating your turn signals when someone is alongside you, waiting a few moments and then starting to move over is occasionally very effective tho.:B
I do just love those folks that are in the left lane on the freeway and see your turn signal when you need to move over and pull up even with a corner of your rig and hang there.:E
There's a relatively easy wiring change that will cause the side marker lights on many RV's to flash with the directionals, as well as lighting with the other clearance/ID lights.
The basic "Crossfeed" method works with two wire non-LED fixtures.
http://www.danielsternlighting.com/tech/markerflash/markerflash.html
38,776 PostsLatest Activity: May 15, 2026
