- CG_DawsonExplorerRefrigerator drain?
- Dale_TravelingExplorer II
bass n bob wrote:
Low point will only drain the lines while a separate drain for the tank ensures you get every bit of water beyond what the pump will pull out. Also makes it easier to drain after sanitizing.
thanks for all the great help - I think you got it. It is on the bottom of the fresh water tank. Why would they have a separate drain for the fresh water tank? I would have thought the low point drains would cover it. I turned off the faucet and the water stopped.
Camping buddy's fifth wheel has what looks like a 1 1/2" drain valve. Dumps the tank in seconds. I have a 3/8" petcock to drain my tank. I open it and come back the next day to finish what I was doing. - rgatijnet1Explorer III
fla-gypsy wrote:
To my knowledge all FW tanks have a drain.
Haven't heard of too many that require you to crawl under the RV. My low point fresh water drain is right inside my basement wet compartment. - fla-gypsyExplorerTo my knowledge all FW tanks have a drain.
- Pop-Pop_CExplorerFresh water tank drain? May not be closed tight?
- bass_n_bobExplorerthanks for all the great help - I think you got it. It is on the bottom of the fresh water tank. Why would they have a separate drain for the fresh water tank? I would have thought the low point drains would cover it. I turned off the faucet and the water stopped.
- fla-gypsyExplorerFreshwater tank drain?
- rgatijnet1Explorer IIIIt sounds like the overflow for your fresh water tank. The tank will sometimes drip for quite sometime after the fresh water tank is filled. I believe that someone installed the faucet to prevent the water from running all over the ground after the fresh water tank is filled.
- bass_n_bobExplorerit does look like a regular faucet. It is not the AC drain. If it was to wash your DP I would assume it would be more readily available than requiring me to go all the way under the chassis to connect a hose.??? It has stopped running after about 20 minutes and about a 1/2 gallon of water.
- donn0128Explorer IIAC condensate drain. You will see the same thing under the front of your car.
38,759 PostsLatest Activity: Nov 14, 2025
