- TrackrigExplorer IIWhen you looked at the tank and it was half empty - was the slide out? If yes, pull the slide back in and then check the tank. Don't fill the tank with the slide out.
When the slide is out, the fluid has gone into the cylinders to push it out. When the slide is retracted, the fluid will return to the tank.
Bill - usersmanualExplorer
lacofdfireman wrote:
I have a 2007 Georgetown 350DS with a Double slide. Large Living room slide and a small bedroom slide. I was looking at the tank that holds the hydraulic fluid and it's only half full. Is this normal? And what type of hydraulic fluid is used in the reservoir?
Slide is a Lippert..
aw32 hydraulic oil most likely maybe dextron atf oil also
38,756 PostsLatest Activity: Oct 09, 2025
