cencerrita's avatar
cencerrita
Explorer II
Mar 11, 2016
Wheel trim cover removal Four Winds Majestic 27G
Just read a good archive forum 2010 about removing wheel trims. Guess this will also apply to our 2009 E450 base which is a Cruise America 27G. Unfortunately the RV is now in storage a long way from me so I can not check the trim nuts for dimple marks.
Can anyone tell me where to get the T handle that people talk about to remove the wheel trim cover? I want to get the right tools for our next trip which is going be nearly 3 months.
Thanks
  • I've been wondering about my wheel covers, thanks for all the info.
  • Cruise is now using a fully snap in set of Dicor wheel liners. The old ones with the two securing lug nuts were awful.
  • DrewE's avatar
    DrewE
    Explorer III
    x2 on getting a normal (deep) socket of the right size. The T handle tool that Dicor provides is rather light-duty and in my experience liable to break if the wheel simulator nuts are too tight or rusted on or otherwise don't really want to come loose. If you use a breaker bar or similar for the lug nuts, it's just a matter of obtaining a different socket.
    Maybe it's a well-known trick, but I learned by watching a mechanic that you can determine the actual nuts that hold the simulator in place (vs. the dummy ones on the simulator itself) by tapping them with a wrench handle or something similar and listening to the tone of the tunk. It's a lot easier than staring and trying to see which ones have the slightly different center.
  • j-d's avatar
    j-d
    Explorer II
    We have Dicor simulators on our E450, same stud/nut size as E350. Went with a 1/2" drive deep socket and ratchet. Socket size is 1-1/8" and the ones sold a Lowe's ("Kobalt" Brand) work well. The "hex" part is deep enough to hold the full edges of the stainless jacket over the steel nut. Standard socket can't reach the "hex." I want them tighter than the Dicor tee wrench will get them, and if they rust a little, the Dicor tool won't loosen them.
  • Thanks, sorry for slow response but there was a web problem (it would not open) with this topic which has now been fixed by the forum support.
  • My original Cruise America "wheel covers" kept falling off. Originals did not require a wrench to remove. Originals were like a big hub cap, just snap on and off.
    Then I actually got "wheel simulators" that are held on with a lug nut and coupling nut, that does has have a dimple in it. Those don't fall off.
    Different sizes available, so make sure you get right size. I also have the "pliers" type, but they are not as strong.
    http://www.pacificdualies.com/31-2000lw-lug-nut-wrench/
    http://www.campingworld.com/browse/skus/index.cfm?skunum=6837&rewrote&affiliateid=5193&gclid=CJXyjczIuMsCFRSPfgodLJQDQw
