superrayzor wrote:
timmac wrote:
What year and what chassis do you have, you might need sway bars or adjust the current ones, as to wind you will get use to it, takes time but you will be a pro..
2016 F53 chassis. It has billstein shocks installed on it which is nice. After the Safe-T-Plus if I still have issues, I might consider the sway bar. Is it just the front, the rear, or both? What recommendations?
Yes it has sway bars installed already but what you need to do is do the CHF is what I think it is called, adjust the sway bar tension on the sway bars to stiffen up the chassis from swaying side to side, someone on here post a link for him about this on the F-53 chassis..
