garry1p
May 09, 2014Explorer
Your AC cord or male plugin may be bad, the 120v CG pedestal may have popped the circuit breaker or the transfer switch may be stuck on generator.
1. Check your shore power cord. If it is on a reel they are known to have problems with the contacts.
2. Check the shore power circuit breaker (flip it all the way off then back on).
3. If you know where the transfer switch is located rap on it with the handle of a screwdriver.
The power from the generator goes through your RV circuit breaker panel so the problem sounds as if it is the transfer switch or my best guess the power cord.
38,707 PostsLatest Activity: Feb 28, 2025
