Donna_and_Rob's avatar
Sep 30, 2014
When to check tire pressure. Hot or cold
First thing in the morning the front tires show 100psi about five miles later they show 110psi. Which should I go by? cold or hot.
I'm thinking hot.
  • darsben wrote:
    ScottG wrote:
    Cold. The tires are designed to heat up and increase in pressure.
    THIS is the correct answer
    Yup, x3.
  • Install a TST Tire Pressure & Temperature Monitor and you'll never have to worry about or checking the pressures again (just turn on the monitor & you're done) !
    If the temperature rises to dangerous levels (165* +) or if the pressure drops by x percentage or pressure the monitor alarm will sound to notify you.
    Install sensors on your toad or trailer too & you'll know the pressure & temp while you tow !
  • Cold. The tires are designed to heat up and increase in pressure.
