Mikeeg
Dec 21, 2012Explorer
WHERE HAS ALL MY POWER GONE
Here is my storm story , I had run geny for three days suppling the house with the most needed creature comforts 110 v water well,Light and coffee. Then on fourth day no power out of front storage compartment outlet which has GFI with inverter plugged into it ( not sure if I pulled the plug or not memory lose). I moved cord to rear compartment outlet which had power and went on for next eight days then house power was restored by great out of state power crews. The next day after nice hot shower I start to check MH outlets for problem and find there is no power in TV cab.outlet , bath outlet with GFI and front lower outlet at passanger side floor outlet but have power in all other outlets. I check and try to reset GFIs but no luck. I pull outlets and check wire connection and put test light to them with no power, check all breakers in panal and wire connection to breakers all tight and all are hot still no clue. Question to all where has all my power gone long time passing!!!
I have called Newmar tech support who pullled up my Vin. and E-Mailed wire diag. which shows all outlets on one circuit, they seem to think it is a lose wire on one of the outlet but I have power on other outlets in between powerless outlets. HOW CAN THAT BE*** I also have power coming in to the inverter in the compartment which has the dead outlet . HELP IS NEEDED!!!!!!!!!!!!!!!!! LONG PAINFULL STORY TO TRY TO PUT INTO WORDS.
__________________
__________________
