I did reset fuse on inverter which did not seem to be popped but did not check with test plug but will do so in the am:. Could it be a problem before the panel as transfer switch or 50 amp. plug.I would not think the outlets would be without a breaker in the panel but possible there is another breaker that Newmar is not tell me about.Crazy thing there is power in outlets up stream and down stream also. I may have to call in a tech or elec.guy.But still will be checking transfer switch wiring for lose lugs in the am:. Well good thing is spring is still four months off and I'am winterized.
