- ferndaleflyerExplorer IIICostco or Walmart for my DP. Amazing how proud the RV dealers are of the same blades.
- wa8yxmExplorer IIIOn my Coach. most anywhere.. They are right at the limit of what I find in the Auto Department of "Superstores" or on the rack at placces like Auto-Zone.
1 inch longer and I'd be into truck stops.
Fact. If yours are 1" longer than mine. odds are you can "Downsize" an inch and never notice
I do sometime have to modify the mount a bit. (IE drill a hole larger) - Sam_SpadeExplorerAnd for a slightly different question (maybe):
Does anybody have a source for REFILLS ??
That is, just the rubber part, none of the metal. - sch911Explorer
Twomed wrote:
accsys wrote:
Even though our coach came with 32" blades we have always replaced them with 28" Michelin blades from Walmart - much cheaper, clears the windshield very well, and less drag on the motor.
x2...for years now
X3 - TwomedExplorer
Ava wrote:
I use 28s which I buy from Costco for about $10. The wiper arms on the motorhome are too big for the fittings supplied but I drill out the center rivet and use a nut and nyloc bolt. Works fine for mine
Yeppers!....15 minutes saves $40+ that's $160 an hour...real beer money. :) - garym114Explorer IITrico - they have the right size and right attachment for your wiper arm. Select RV in the first dropdown and go from there. Most all MH listed.
https://www.tricoproducts.com/
Find the right number and search Amazom - AvaExplorerI use 28s which I buy from Costco for about $10. The wiper arms on the motorhome are too big for the fittings supplied but I drill out the center rivet and use a nut and nyloc bolt. Works fine for mine
- lawjohnsonExplorerWell the RV dealer in my area wanted $100.00 for the 30 inch ones. I stopped at Walmart on the way home and purchesed a pair for $25.00!
- kdkExplorerPaid that big price once, mine had the big J hook. Cut last 2 inches off, went to junk yard and got 2 arms off ford pickup for $5.00, cut 3 in. off that arm, overlapped new smaller J hook on old arm and welded. Now buy new 28 in. rainex latitude blades for $8.oo. Just an idea
- Johno02ExplorerNapa parts store.
38,763 PostsLatest Activity: Dec 13, 2025
