wolfe10
Jun 29, 2016Explorer
rgatijnet1 wrote:
ON my Monaco, if the bong is not going off when the jacks are retracted, you probably do not need to add fluid. The way it is added is to lower ONE jack 5" and if the bong is going off, they might be a little low on fluid. Then you slowly add fluid until the bong stops. This insures that when any of the jacks are still down more than 5", the bong will be sounding.
Yes, with RVA jacks, this IS the way to get the proper fluid level.
Extend ONE jack 5". If the "jack down" alarm is not sounding, your fluid level is fine or could be high. If no alarm, lower jack another inch. If still not going off, drain fluid or determine cause of "no alarm".
If with the jack extended 5", the alarm is going off, fill until the alarm just stops. Easy job with two people or one with really good hearing.
38,776 PostsLatest Activity: May 14, 2026
