B_s's avatar
B_s
Where is the tire pressure sticker hiding?
We have a 2004 Georgie Boy Cruise Master and cannot find the sticker that states what the tire pressure should be. Can anyone tell us where to look for this sticker? We have looked behind doors, drawers, etc. anybody know where it might be.
  • downtheroad wrote:
    Look on the side wall of the tire near the edge of the wheel/rim.
    X-2, It has to be on the sidewall of the tire as required by the Feds. You might need a flashlight and a magnifing glass to read the tire pressure on the sidewall they can be in small print! You also can look up your tire pressure specs on your tire manufactures website.
  • Sit in the drivers seat. There should be a placard where your left elbow is! No,max pressure on the sidewall is not the correct pressure. That is disinformation! Weigh your coach when you can. Until then, use the wall plac.
  • The best answer for proper tire pressure is to have the RV weighed, then set tire pressures per the tire manufacturer's load/inflation tables.
    The Michelin RV Tire Guide has lots of good info.
  • Drivers door frame sill
    Glove box
    Owners manual
    Load chart for tires..based on weight
