beckid's avatar
beckid
whete is my fresh water tank fill valve?
Trying to figure out where the valve is to direct city water into the fresh tank. Looked at the online manual and the photos are blacked out. No valve close to the inlet valve. Blue valve jndle by the water pump but not sure this is the one. Ideas? Anyone have a photo? Fleetwood Fiesta 34N. Same Op Man as Terra 2008.
  • i had asked the same question of our 2002 FR Windsong. Used to a gravity fed fresh water tank in our Winnebago, discovered there is a fresh water tank inlet next to the city water inlet in the basement. problem with that is it lacks a way to sanitize that i can see. and still haven't found the low point drain to clear it and add fresh.
  • Look for a valve in the wet compartment. Connect to city water connection, then turn valve to fill.
  • I asked the same thing for my 08 Fiesta 34B and even though the book says there one there is not in mine if you have one it should be by the city hook up
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    It is possible you do not have one but if you do it is usually next to the fresh water inlet in the basement.
