Thunder_Mountai
Nov 06, 2016Explorer II
Mile High wrote:
Hey, I'm doing the same thing on my Meridian. I actually bought the DD24SCX7 on Amazon and it showed up damaged so I returned it. I will go local here for $650 - but caution, they redeisgned the stainless versions and not sure of the fit. I'm debating grabbing the prior version while I still can vs the new one (DD24SAX9).
Are you doing the work yourself? My first thought it to occupy the bottom two drawers so the top drawer is accessible, but it might drain better occupying the top two.
Thanks for the reply. Yes, I would do the work. Only problem is my unit is a 40R. Check out the floor plan. The full wall slide where the cook top is has water and power, but for the life of me I can't figure out how to get the gray line hooked up. With a static sink and drain line I could install it on the other slide but would loose use of all drawers under counter.
38,778 PostsLatest Activity: Jun 10, 2026
