Ocean Mist wrote:
Kayteg1 wrote:
Somebody pointed that in discussion, but I would highlight what would be starting point for me.
Do you value safety of your life more, or are bells and whistles your priority?
Older Prevost will save your back in roll over accident.
Will newer Tiffin or Nemar do that?
Most of the time it is not just your back, but back of your wife, children, grandchildren....
Hi Kayteg, So what you are saying is that Prevost really makes a quality chassis that will protect us in a roll over. That is a valid point since we will only be getting older as we age... I heard that the Prevost should last 1,000,000 miles, and that the Chassis is DOT Certified. I need to research what that means but, are you saying that Tiffin or Newmar are not DOt certified Chassis?
Ocean Mist, I, too, am not sure of what DOT requires to be certified. Prevost chassis are commercial bus chassis's used to carry millions of people around the country in passenger buses.
If a person orders slides, they are installed at the factory and the bus arrives at the converter complete. The exterior material is stainless steel and/or a kevlar composite fiberglass.
We had a 2008 Monaco Dynasty that we ordered at a California dealer and took a factory delivery in Coburg, OR. Looking at the structure behind the front fiberglass while the generator slide (front) was open only showed some small braces holding the fiberglass in place. There was absolutely no real protection. 99% of RV'ers will NOT be in an accident.
The frame on a Prevost has real front and rear bumpers. There is a thick steel frame that constructs the front of the bus. I happened to see one that was involved in a serious accident where a lot of the bus was damaged at the driver's side front. It is built like a tank. The front driver's side headlight area was severely damaged including the electrical bay under the driver's seat. The windshield was still in place but cracked.
I know every accident is different but it only takes once to end everything. People can still get seriously injured in a Prevost including death. Wearing seat-belts, keeping tire pressures correct, not speeding, etc. helps form the whole safety picture. The solid structure of a Prevost is a good start.
Just my opinion.
MM.
