Gjac
Sep 16, 2014Explorer III
I think the Daybreak may be 32 ft and the Mirada 35 ft 3276BH vs 350DS that is why the wheel base is shorter on the Daybreak. Does the Mirada have the full basement storage? Some do and some had the small cutout doors. Some Daybreak and Mirada's had the large door and pass through in the rear under the bed and you can store 2 bikes and more in there. Not every model had this. I would check the weight of each MH and the CCC of each. I would check the size of the FW tanks if you plan on doing any dry camping. Does each have the same AC setup 2 AC's. Are the batteries easily accessible? Some battery trays are on a slide out some are under the stair way and you can fill and test them easily. Do either have any header mods or ECM performance chips. Do both have 2 slides? Do either have a refer in a slide? Any suspension Mods on either MH? If all things are fairly equal I would choose the one with the most CCC, largest FW tank, most cooling, most storage and best performance. If the Daybreak is 32 ft it should be lighter and have a little better performance. Hope this helps.
