Ro646a's avatar
Ro646a
Explorer II
Mar 03, 2018
Will I have to add anti gel to my diesel fuel?
We are in North Carolina overnight on our way home to Michigan via Kentucky. I put anti gel in my diesel when I left Savannah this AM. Do they put anti gel in the fuel here, or must I add my own?
Thanks
❚ Did you see the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions, as doing so can delay responses to your thread. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
  • DutchmenSport wrote:
    Northern states adjust the anti-jell based on the season of year. They've been doing this for years now. Temps would need to get to, something like, 30 below zero with diesel blends available today before jelling would occur.
    Maybe so but the blend in a southern state probably will not have it blended - I asked at a Flying J in Missouri on the way south in December and it was not highly blended like in Minnesota
    Put it in better safe than sorry - a service call would be about $500 just paid that 12/27/17 in MN and your towing service would not cover it due to your error -
  • Northern states adjust the anti-jell based on the season of year. They've been doing this for years now. Temps would need to get to, something like, 30 below zero with diesel blends available today before jelling would occur.
  • I am from Ohio, and you will have no problems as all the fuel up north will be winter blend.
  • If you go to a regular gas station they will have type 2 diesel. It works pretty good but I lived in very cold country and always put an additive in my tank before I filled up.
