Gjac
Aug 29, 2022Explorer III
Will this work
Last year my genset stopped working in my MH. I rarely used it anyway except to exercise it. However, I did use it whenever we had a power outage due to a storm to keep my refrigerators cold. I have g...
Gjac wrote:rgatijnet1 wrote:Mine only has a 12v plug in the rear. I could hard wire an inverter directly to the battery there but for once a year think it would be easier to just use jumper cables to the MH which already has a 230 AH battery backup system and an inverter. Do you have the Ford Escape?
My Ford hybrid has a 120 volt outlet that I can use when the motor is idling. This is large enough to power most refrigerators. Are you sure that your Toyota does not have a 120 volt outlet that you can use. Much easier than rigging up anything else.
