BillMFlExplorerApr 26, 2013Window AC projectremoved rear window today without breaking it and installed plywood replacement. Next will be bracing and sill on inside before AC can be installed. Show More
mlts22Explorer IIMay 09, 2013Impressive project. Do you have an onboard generator for when you need to run the A/C longer than the batteries can hold out?
Related Contentwinter projects5th Wheel took out rear windowSmall Window AC vs Roof Top AirAC WINDOW UNITWindow unit style AC
