BillMFlExplorerApr 26, 2013Window AC projectremoved rear window today without breaking it and installed plywood replacement. Next will be bracing and sill on inside before AC can be installed. Show More
Arizona_KidExplorerMay 10, 2013I don't think a Honda 1000 will run your AC. On those type of units the start up power needed is usually double the BTU's. So an 800 BTU AC will require 1600 watts of start power. I would also suggest the Honda 2000.
Related Contentwinter projects5th Wheel took out rear windowSmall Window AC vs Roof Top AirAC WINDOW UNITWindow unit style AC
