BillMFlExplorerApr 26, 2013Window AC projectremoved rear window today without breaking it and installed plywood replacement. Next will be bracing and sill on inside before AC can be installed. Show More
Arizona_KidExplorerMay 10, 2013I thought is was bigger than 5000 BTU, in that case a Honda 1000 may work fine.I would still recommend the 2000, it will give you a lot more flexibility.
Related Contentwinter projects5th Wheel took out rear windowSmall Window AC vs Roof Top AirAC WINDOW UNITWindow unit style AC
