- AikenRacerExplorerJust tried the mister tubing and it worked great! Thanks guys!!
- MountainAir05Explorer IIOur O'Reilly auto has it on spools in the back. As stated, just take in your size or the nipple you are connecting too.
- DSDP_DonExplorerThe drip irrigation tubing is a good idea. It's definitely weatherproof and flexible enough to work. If it doesn't want to stay on the nipples, use a small tie wrap.
- mikimExplorerHad the same problem and none of the Auto parts stores had the correct size. I discovered by accident that on our Allegro it was the same size as the 1/4" drip irrigation tubing. So far it has worked.
- jplante4Explorer IIReplaced mine this spring. Any auto parts store has vacuum tubing. Just take a sample in for the correct size.
Or you could get the clear Tygon tubing at a plumbing supply store. - TrackrigExplorer IIAny Napa store or Auto Barn. I'm sure a Kenworth or Freightliner shop will have it also.
Wiper hose.
Bill
