ezgoinExplorerOct 20, 2016Windshield washers won't sprayMy washers won't spray! The wipers work fine, but the washer won't spray even though there is plenty of washer fluid in the tank. Any ideas or suggestions? Thanks, Bill
KennedycamperExplorerOct 20, 2016Listen for the pump. No noise, check for voltage at pump. You hear noise, check pump for clog.
Related ContentWindshield washer OK for winterizing waterlines?Windshield washer fluid in low temps?windshield washer motorWasher/dryersWindshield Washer Nozzles
