haste_maker's avatar
haste_maker
Explorer II
Sep 17, 2018
Windshield Wipers
I have a 2007 Allergo 32BA that I need to replace the windshield wipers on....I went to my local NAPA store & they couldn't help me...does anyone here have the same coach that could tell me where to buy some wipers?
  • 2 times using 28 inch blade. Mine from factory were 32 inch blades. Replaced with 28 inch and cannot tell any difference. Never looked at the sky through where the top 2inches were nor down on the road where the bottom 2 inches cover. Pay less than $10 versus $35 or 40.
  • Go to Walmart and check their wiper selection.
    I also changed to a slightly shorter wiper which is a lot cheaper.
  • I just replace the rubber strip. $11. A little tedious but not bad.
  • Executive wrote:
    WalMart has RainX supreme blades for $9.48. Get the 28" ones and you're in business. I just replaced both of mine and I don't even drive in the rain...Dennis
    This works on my Allegro 36LA.
  • want-a-be wrote:
    donn0128 wrote:
    I seriously doubt thaat Tiffan or any MH mfg has special made wipers. If you cant find the size you need at your local auto parts store check with a truck stop. They will have longer ones for large trucks.
    Well doubting Thomas!! Give them a call!!
    Lol
  • my wipers are held on by screws thru the arm to the blade, not U-hooks or snap in pins etc.. 1997 Bounder
    rubber NOT refillable, not spring clip rubber filler replacements
    i took a blade to NAPA
    they matched me up with the correct size blade and adapter fittings for the blades with new screws to fasten the new blades to the ARM
    blades $9.48 each adapter fittings $9+, total $31.xx
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Their books and computers do not list RV's.. I took a tape measure to mine.. 28" as I recall. (yours may be different) and all was good.. I did have to drill out a hole a bit to mount 'em but .. they work great.
