Dec 28, 2015Explorer
I've got two of those chairs. The front, right compartment is a two level compartment. The higher level is shallow but deep enough for one chair the long way. The next compartment on the right side (just aft of the entry door) is much wider than deep. It is also tall. I got an extendable shower bar with two mounting cups. One cup is cut-out half way around. One side of the second chair is put on the tall ledge that extends out from the water tank about 8". Then the bar is installed and holds up the other side of the chair, which leaves plenty of room to store stuff under it.
Works well for us. The MH is in storage or I would take some pictures. If you still have questions come next spring, let me know and I will get pictures for you.
38,763 PostsLatest Activity: Dec 05, 2025
