1 seems to be fine, tran shop looked at it and of course it did not have the issue probably cause it wasn't driven under a load. It seems to take about 30 miles as long as there is a grade and happens when I am pulling a load. Tried to duplicate the issue w/o the trailer and I drove around aimlessly trying to get it to fail.
2 speedo does NOT read correctly
3 shifts normal
4 yes at the beginning of a trip, until I hit a hill or a bit longer miles so it might be heat related
5 no light on
6 n/a
7 2000
8 after going up hills and have a decent load it will to shift into overdrive so I am stuck going pretty slow to keep the RPM's down
9 I believe so
10only service work done was trying to fix this issue. Shop replaced a cable ... Apparently not the issue
11 I hear/feel 4 when OD is working
12 no slipping that I can feel
13 not sure
14 assuming it is accurate in OD it sits around 2200-2500
I really appreciate everyone's effort in helping me resolve.
