creeper wrote:
There must be a reason they are getting away from them.
According to WinnebagoWhy change? The advent of new diesel emission standards requires chassis components to be placed in the basement space previously used for our TrueAir compressor package and the future availability of that cooling unit package is in question due to new refrigerant regulations that require larger re-designed compressors
OP,
We had basement air in two coaches, an Adventurer and a Journey. We like the basement air in both. They were definitely quieter in the living area and quieter than a bedroom roof air from the same time frame.
There was an issue that I didn't like. One could not decide which compressor(s) were running. The management system used the number one compressor, by itself, if the temperature in the coach was no more than one degree above the set temperature. That created situations in which the first compressor was started because of a one-degree differential and it was able to maintain that differential but could not bring the temperature now. So the one compressor could run for hours, unable to satisfy the call, but "not needing" the second compressor.
Our current coach has two roof heat pumps. They are quieter than roof heat pumps used to be. I do like running the front unit at night and leaving the back one off.
This summer in 95º temperatures, I found that I had to close the bedroom vents to force all of the cooling capacity to the front. That worked.
We did not see a similar issue with the heating cycle, during the winter. But then, the heat cycle only works down to the high 30's.
Tom
