Finally_Time
Apr 04, 2021Explorer
I had a 2013 Winnebago Vista 27N. I flat towed a 2013 Honda CR-V, weight about 3,900 pounds. I couldn’t tell the difference in power or gas mileage when towing. The 27N is a little hotrod; great going over the mountains.
I had it seven years and made many summer trips in the west. The one ac was adequate if you wanted it cooler not cold. Had to stay on top of the temperature, that is had to turn on the ac before the inside got really warm. It kept the temperature about 15 degrees cooler than outside.
The windshield fans are helpers for defrosting the windshield. If you are in an area where the windshield fogs up they are very useful.
I had my right side mirror removed by a semi in a rest area. If you don’t rip the mounting bolts out of the side, they would be easy to remove and reattach. Four bolts hold the housing and the electric connection is a plug in.
38,782 PostsLatest Activity: Sep 10, 2026
