Bumpyroad
Nov 08, 2017Explorer
gutfelt wrote:
complete waste of time;; disconnect plastic line and it will drain itself;;its the main water feed line to solenoid and solenoid itself that need to be blown out (I jumper the solenoid)
yep, I just unhooked mine at the solenoid, put a standard hose shut off there, let feed line to icemaker drain out (I assume the parts of ice maker inside freezer get sort of chilly when in use) let pink stuff squirt out the fitting and shut it off.
bumpy
38,782 PostsLatest Activity: Sep 10, 2026
