kioticoachman
Nov 18, 2015Explorer
Winterizing Suggestion Update
Got into the cold or fresh water draining an already having a problem with the draining. The unit has, as best as I can describe, black plastic "T" drain valves. Not sure how they operate as I turn the T to various positions but the fresh water does not drain? This is a 2001 Ford Coachman. There appears to be a clip on the valve but not sure if this clip is a lock an has to be removed in order to pull up on the T to allow the water to exit? Not sure how to post the picture of the Valve? Hope that this will help? Any an all suggestions will be appreciated. KC
