Geeze
Nov 17, 2018Explorer
Bren53 wrote:
Well that didn't work!
Ok we went to winterize MH and still not doing something right! We connected hose and flipped up to winterize, I opened faucet and turned pump on but it didn't suck any antifreeze into the lines. We've never had so much trouble trying to winterize a MH! What are we missing? I'm trying to upload a picture but not sure this will work
2019 Coachmen Leprechaun 319 mb. We finally found the low water drains and have lines all drained. Our problem is we still have around 2 inches of water in the FW tank we can't seem to find a way to drain it completely! So far dealer was no help at telling me if there was another drain to complete this. I've called Coachman 4 times and still haven't heard back. I have a hard time believing that this water has no way of being drained out. I know we can put the pink antifreeze in an all will be fine but still...
Anyone out there have this class c that can walk me through draining all the water out of FW tank?
Thanks
We also have a 2019 Leprechaun 319 MB.There is a shutoff valve in the line where the freshwater comes out of the tank. Once you shut that valve the pump will pull antifreeze from connection on the outside.
38,766 PostsLatest Activity: Jan 10, 2026
