Effy
Feb 01, 2016Explorer II
Wiper blade replacement
I read somewhere a while back that instead of paying $30-40 each for wiper blade replacements that NAPA can replace just the rubber part on the existing hardware. Is this true?
down home wrote:
I'm a little confused on this. Our blades are just 28 in. I bought the blades from CW and pulled the old ones out of the frame. Inserted the little metal strips and back into the frames. The bracket is attached to the arm with two little screws.
The coach is not here for me to look at. Is there a different bracket or another way to just buy an auto type entire blade assembly and detach th old one and clip on the new one, just like an auto. If there is I really need 32 in assemblies.
