Has anybody found an alternate to Winnebago blades. I have a 27N and they want $40 each. Mine are only 18 months old and the RV is always covered. Winn P/N # 189546-09-000
I use standard blades found in any auto parts store. The issue isn't the blade itself but the size of the bracket that attaches to the arm. So I drill out the rivet on the bracket of the blade, Remove that bracket, put in the one that came off the rv, run a small bolt through and done. Cheap and easy.
