Dutch_12078
Nov 14, 2014Explorer III
We have a 2001 Georgie Boy Landau on a 2001 F53 chassis with the V10 engine. As said, the Bigfoot levelers are easy to use, and to answer the "Air Dump" question, no, you do not have an air ride suspension system, so that feature is inactive. The same panel is used in DP's where the dump feature may be used.
One item to watch for/check on your 460 V8 is exhaust manifold leaks. The passenger side rear bolt is particularly vulnerable to breaking and possible manifold or head cracking.
