mhbell
Nov 14, 2014Explorer
Dutch_12078 wrote:Thanks for the heads up on the exhaust manifolds. Guess I will pull the doghouse and have a look at the engine. It has 42,498 miles on it. I am thinking it might be a good idea to check belts and hoses and change fluids. So far the unit runs good and starts right up. I have already modified where the TV went and replaced the Analog TV with a HDTV and replaced all of the Light bulbs with L.E.D. Lights. Details in my Blog at http://rvbloggers.wordpress.com/ or Click Hereclick here
We have a 2001 Georgie Boy Landau on a 2001 F53 chassis with the V10 engine. As said, the Bigfoot levelers are easy to use, and to answer the "Air Dump" question, no, you do not have an air ride suspension system, so that feature is inactive. The same panel is used in DP's where the dump feature may be used.
One item to watch for/check on your 460 V8 is exhaust manifold leaks. The passenger side rear bolt is particularly vulnerable to breaking and possible manifold or head cracking.
