down_home's avatar
down_home
Explorer II
Jun 16, 2013
Hamburger Press
The Fourth, the Family will be here and I need to make several hamburgers. We have found some full size fresh Briouch buns that we like and are full size for hamburgers.
We have a tupper ware patty former and a metal one hidden in some corner somewhere.
What I want is a traditional full size or 5 inch hamburger press or patty maker. I have found one or two on the Internet taht are eighty dollars or more and don't look that well made.
There are countless offerings of the Chinese, under different names of 4 in, 4 3/8 in, 4 1/2 in, with most being 4 inch.
I want an adjustable thickness 5inch or a little larger hamburger press.
Anyone seen such a critter?
  • Take 2 small bowls the same size.
    I weigh the ground meat into 5 oz balls.
    Put the ball in one bowl. Than press the other bowl inside the first one that has the meat.
    You can make the burgers any weight you want.
    Get a helper it will go fast. Each patty will be the same.
