Baja_Man's avatar
Baja_Man
How to REMOVE brake drum races using a shop press?
Hello all--
I wanted to see if anyone has a method for removing brake drum/hub bearing races from trailer brake drums using a simple shop press.
I know there are kits that use machined alum discs of various sizes to install races and seals (either with a hammer, press, and air hammer) but have never seen how to remove them using a shop press.
I know how to remove races using a brass drift and hammer. You must access race at an angle, as the race can not be hit vertically with the drift. This is what makes using a press a challenge.
So.....how can races be removed from brake drums using a shop press?
Maybe it's so simple, I can't see it or think of it!!!
Thanks!
