Super_Dave
Feb 09, 2019Explorer
More smoked cheese
With morning temperatures at a balmy 16 degrees it seemed like a perfect morning for a cheese smoke, plus, my stash is getting low. 10 pounds of medium cheddar and 4 pounds of Swiss.
garmp wrote:
Holy Cow!!! magnus, you did it again. Jim Beam marinate. Gotta try that!
I have a couple of Amazen tubes I use, but my preferred method is a soup can with holes along one side, 20 or so, a hinged open end with a cheap pencil soldering iron from Harbor Freight. Fill the can with Alder chips, insert the soldering iron and let it smoke for about and hour or so. I generally refill the can, or in my case, use a second can full of chips and continue to cold smoke, depending on the amount of cheese.
Marinade! WOW!!
Super_Dave wrote:I have a 12" Amazen tube that works great for us. I've used it with my grill box (no heat) to make smoked cheese and it works well. You're our inspiration for the smoked cheese gambit, Dave. :C
I use an Amazen tube with no other heat. You don’t want your box temp to get over about 80 degrees. Before I bought my tube, I use to put pans filled with ice under the rack of cheese. My smoke time is 3 hours and my rest time is usually a minimum of 10 days.
Rolling Condo wrote:
What temperature do you smoke at?
