fla-gypsy wrote:
Just because you use 80/20 beef means nothing. Different cuts of beef have different flavors. The problem is not the seasoning, it's the beef!
Absolutely! You first have to ignore the fact that Walmart other big chains use pink slime, they don't. They along with other chains use meat ground from meat destined to be hamburger. The only real questionable meat is from the big chubs, you won't ever get a decent burger from meat jammed into a tube.
If you buy from a market that has a loose ground burger, preferably with a little pork in it, and it is 80/20 you're 75% of the way there.
Never pack a patty, shape it. Don't make it too thin. Make a small indention with your thumb in the center. Flip it once and don't overcook. It must be a little loose and be packed to just hold together.
As far as flavor goes,good burger doesn't have to have anything else. The flavor is in the fat and if its its there. Softened onions and or peppers are good as are a lot spice mixes from lemon pepper on. I'm partial to Webers Deluxe hamburger spice.
We buy what is know as Boston Burger here which is 80/20 beef and pork. we have to buy it from one location that grinds its own, others have introduced a pre-packaged that sucks.
