usersmanual's avatar
usersmanual
2001 newmar M.Air DP TV systems
looking for anyone that knows how the TV cables are run from factory on a 2001 newmar mountain air Diesel unit
\\I know where the park cable in is;; I know where the front and rear TV cables are;; the problem is the cable outlet inside the MH is no where near where the wineguard splitter system is mounted that goes to front and rear TV. The roof antenna system is located where the TV cables and wineguard splitter are so this whole deal makes no sense to me? this unit has been used by this couple for 7 years and they have to run the park cable through the front DS window to get TV
  • Johno02 wrote:
    If you have an OTA antenna with a power supply panel, the park cable should be attached to one of the terminals on the antenna power supply. When the antenna power supply is turned off, the park cable should be connected to the TVs, instead of the antenna. Most of the antenna power supply panels incorporate an A-B switch for that purpose.
    thanks for the input/reply the OTA antenna amp on this Newmar MA
    is different than the norm like the one your referring to
    and has a stand alone cable to the switch box for the ota tv system
    There is a cable TV outlet in the cabinet where there is a dvd player and a radio/amp combo
    when I run a jumper cable from there across the room to where the Tv cables are the tv works great
  • If you have an OTA antenna with a power supply panel, the park cable should be attached to one of the terminals on the antenna power supply. When the antenna power supply is turned off, the park cable should be connected to the TVs, instead of the antenna. Most of the antenna power supply panels incorporate an A-B switch for that purpose.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,800 PostsLatest Activity: Dec 05, 2024
