pianotuna's avatar
pianotuna
Nomad III
Jul 06, 2014
cell phone coverage in northern Manitoba
Hi,
Does anyone have experience or advice about using a cell phone in Manitoba?
Their system is, I believe, mostly CDMA.
  • Yep. You roam on mts. You will have coverage in The Pas, Thompson and Gilliam.
    Cdma will give you Churchill and a bit more on the road.
    Do you know anyone with a dual mode phone, such as Nexus 5? You may be able to swap Sim cards and get access. But not certain of that.
  • Hi,
    By North I mean The Pas, and the train to Churchill. According to Sasktel my Galaxy S4 is not cdma so I'm hooped.
  • Depends what you mean by northern Manitoba. Mts has best coverage, and it is mostly 4g hope. There is still cdma but it is in isolated areas.
    Both cover areas around major highways, but mts does better in Cranberry Portage to Thompson and adjacent communities. There are areas of no service on that Highway.
    Getting away from the highways there is some service in isolated communities. Mts also has service on Nelson River where the dams are.
    Used to carry phones that were dual compliant but there is less need unless you know you will be in an area that needs it.
    Map out where you want to travel and what carrier. If rogers, and you are in certain areas you may want a pay as you go on mts. Not sure about roaming with a sasktel phone. Used to be on mts, but I've been away from there a few years now.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 15, 2026
