BarneyS's avatar
BarneyS
Nomad
Oct 22, 2019
Difference between NiCad and NiMH batteries
My fence post tops for the steps to my permanently parked travel trailer have 2 solar powered led lights with rechargeable - AA NiCad batteries. Do I have to replace those batteries (one is no good) with NiCad or will NiMH work as well or better? Will the built in solar charger in the lights work with NiMH? Is one preferable over the other?
Thanks for any assistance you can give to this electrical novice. :)
Barney
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Corkey05 wrote:
    Charge rate is different, so you're taking a chance of battery damage if you change to NiMH.
    "Nickel-based batteries are best fast charged; a lingering slow charge causes “memory.”
    Ni-Cad memory is one step removed from a MYTH..
    Fact: If you charge and discharge to EXACTLY the same points hundreds of times EXACTLY the same point. Memory develops.. The fence post gets a different amount of sunlight every day so unless the batteries are FULLY charged in the day and FULLY discharged at night no memory save for 100% and that's kind of the factory setting.
    NASA. orbits satellites After hundreds of orbits with EXACTLY the same load on the batteries and EXACTLY the same numbers of full sunlight they develop memory.
    now.. Filaments.. that's another issue
    As you discharge the battery metal from the housing is "Eaten" by the chemicals inside generating electricity.
    As you charge metal is "regurgitated" as it were and deposited MOSTLY back on the shell (housing) however not always.
    FIliments eventually develop. and for those a very very very fast charge can pop 'em like a fuse. Restoring the battery
    You call it memory
    It is really a shorted cell.
  • Frankly, Barney, I WOULD change to NiMh batteries....they are superior.....and I would bet dollars to donuts that that cheap solar charger for your step light is engineered no different from NiMh or NiCd.
  • Thank you Corkey. I think I will just stick with the original type NiCad batteries. Seems that the NiMH give a little bit more charge per battery and that is why I was asking. Thought maybe they were a later improvement or something.
    Barney
  • Charge rate is different, so you're taking a chance of battery damage if you change to NiMH.
    "Nickel-based batteries are best fast charged; a lingering slow charge causes “memory.” Nickel- and lithium-based batteries require different charge algorithms. A NiMH charger can also charge NiCd; a NiCd charger would overcharge NiMH. Do not leave a nickel-based battery in the charger for more than a few days"
    The above taken from Battery University
    That said, I changed to NiMH for my solar powered shed lights and they worked fine.
