nvreloader's avatar
nvreloader
Direct TV dish setup?
When setting up a DT TV dish, I want to check the OEM degree settings.
Do you set up using the face of the dish, meaning taking a 6' level and setting it across the the dish face at the 12/6 Oclock position for the straight up and down postion.
Then set the level across the dish at the 9 and 3 oclock positions for the tilt positions?
Or do you use the lnb arm to zero everything?
The mast will be perfectly dead zeroed when starting etc.
Not quite sure how to dead square and level the dish it self.
Tia,
Don
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Apr 25, 2026
