Horizon170's avatar
Horizon170
Directional antenna's for Local(answered and solved)
I wonder how this compares to the Batwing?
https://www.antennasdirect.com/store/clearstream-4-ultra-long-range-outdoor-dtv-antenna.html
EDIT---How do I make this a HOT LINK?
    well, the mfg's website starts by referring to an "HDTV" antenna. seeing as there is no such thing calls into question everything else the mfg claims.
  • That antenna is for receiving stations broadcasting on UHF channels only. It will not receive the several hundred stations broadcasting on VHF channels unless they're next door to you.
  • Depending on your mounting, it will probably be as good or better than a batwing. In either case, about 70 miles or so is generally max with UHF. With my late-model batwing, and the Winegard booster inside, I have no trouble with 60+ miles direct over flatland. Much past that, the signal just ain't there at all. I have an amplified flat window antenna at our S&B, about 50 miles is good.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
