Bill_T's avatar
Bill_T
Disabling add-ons
My laptop has installed Windows 7 and Internet Explorer 11. I have AT&T DSL, no other choice in my rural area.
The videos are slow to load, frequently stop and reload while playing, generally a pia to use.
I have been searching the internet for cures I may be able to do myself without making matter worst.
One suggestion was to disable add-ons. I found my add-ons and viewed them, some are enabled and some disabled.
Is there a way to tell if I need a particular add-on? Can I disable an add-on and if things go wrong can I simply enable it to correct?
Thanks for any help or suggestions.
  • What kind of videos? Embedded in a news feed? Flash videos? U-Tube videos? Or streaming videos from Netflix or Amazon?
    Not a bad utility to use to locate excessive bandwidth usage is a program called Networx. It will enable you to see what is using your bandwidth and give you some ideas of your actual upload and download speeds.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
