greenrvgreen
Jan 16, 2016Explorer
Dish VIP211k HDD use
I have Dish Pay-as-you-go (PAYG) using the Tailgater and the VIP 211k receiver. I have added a 2tb HDD for DVR use and it works well. Here are my questions:
--Does anyone use more than one drive? I know only one drive at a time can function as a DVR, but can you disconnect your drive and switch in a new drive, use it, and then switch in the old drive and view the old content?
--With PAYG, I understand that you can't access the HDD shows when your sat service is shut down. But once you restart, are all the shows there on your HDD same as before? Or does it reformat and start all over?
--I'm starting to like this HDD DVR so much that I want to back up the HDD as an image. This is NOT an attempt to hack into the data, which I understand is in a proprietary format. I'm asking if an image backkup tool like EaseUS can successfully copy the image and then restore it if the original HDD crashes. Anyone done this?
